99 XJ Rear Hatch/door Latch assembly
sinkrun
I took a look at mine yesterday, but could not remove because I forgot the torx bits. It looks like the electric door lock actuator is a separate assembly attached to the latch mechanism via linkage.
I think what I have will work for you, but I want to make sure its in good working condition. I will be back with the donor this Friday night.
I pulled the 2 latch parts out of the hatch.
1 - plastic handle and lock assembly seen from the outside of the vehicle
2 - internal latch, what actually holds the hatch shut
Everything is in good working order and includes the necessary linkage. Still need it?
