wranglercory Posted July 16, 2010 Share Posted July 16, 2010 My MJ won't run anything over idle after its warmed up to opperating temp. Could my spedo cable that is disconnected cause my problem. The truck is a 1987 MJ with a 2.5 liter AX5 trans and is 4X4. I just thought of this while going through the flow chart of troubleshooting.The chart called to check a speed sensor and I thought it could feed from the cluster to the ECU ???? Just a shot in the dark at this point. Link to comment Share on other sites More sharing options...
Geonovast Posted July 16, 2010 Share Posted July 16, 2010 Nope. Link to comment Share on other sites More sharing options...
wranglercory Posted July 16, 2010 Author Share Posted July 16, 2010 GRRRR This sucks I think Ill start swapping the sensors from my bad 87 to my good MJ one at a time to see if I can get it that way??? Link to comment Share on other sites More sharing options...
Eagle Posted July 16, 2010 Share Posted July 16, 2010 Let's try a bit of Sherlock Holmes style deductive reasoning. The problems occur after it reaches operating temperature. During warmup, it runs in "open loop" mode, ignoring certain sensor inputs and using a programmed fuel map in the ECO to control the fuel delivery. Once it warms up and switches to "closed loop mode." it then responds to input from sensors. Clearly, then, the basic systems are okay and the problem lies with one (hopefully not more than one) of the sensors that get bypassed in open loop mode. The oxygen sensor is one of those, so that's one to check. Not sure if the MAP sensor is skipped in open lop mode. What else is there? Link to comment Share on other sites More sharing options...
Geonovast Posted July 17, 2010 Share Posted July 17, 2010 Is your knock sensor plugged in? I've read that if it's unplugged, it can cause the ECU to make it run in some sort of "safe mode" Link to comment Share on other sites More sharing options...
