gaucho919 Posted June 29, 2010 Share Posted June 29, 2010 Hello I recently bought a '92 4.0 2wd comanche and I plan on converting it to 4x4, I've read that the TJ nv3550 should bolt in, the thing i'm worried about is the clocking for the transfer case, would the TJ tranny clock the T-case too high where it would contact the body? any other advice greatly appreciated... thanks a lot Link to comment Share on other sites More sharing options...
Pete M Posted June 29, 2010 Share Posted June 29, 2010 I have a 99 TJ trans in my 88 and it's close, but doesn't touch. Now, mine is a bit different than most since I have a custom crossmember that raises the assembly up a small amount and I snipped off one useless aluminum tab on the corner of the t-case (which might have touched so I cut it off preemptively), but with a stock truck it should all work fine. Link to comment Share on other sites More sharing options...
gaucho919 Posted December 29, 2011 Author Share Posted December 29, 2011 Pete, what did you do about t-case linkage? I'm trying to figure it out with stock parts and can't find any brackets that fit, did u use a custom linkage? Link to comment Share on other sites More sharing options...
Pete M Posted December 29, 2011 Share Posted December 29, 2011 I had MJ parts and TJ parts available to me and aren't quite sure which links I used (I think I used all MJ stuff). but the bracket is custom. I saw that two unused bolt holes lines up with the imaginary pivot point and so made my own bracket from a flat piece of steel. :thumbsup: Link to comment Share on other sites More sharing options...
Exxon Valdez Jeep Posted December 30, 2011 Share Posted December 30, 2011 I smashed my floor in with a BFH until the transfer case cleared. I don't have a 4wd shift linkage yet, thanks for that pic Pete! I used the AX15 crossmember, clutch, and flywheel. Link to comment Share on other sites More sharing options...
Exxon Valdez Jeep Posted December 30, 2011 Share Posted December 30, 2011 oh, and with the NV3550, you will have to trill a little where the shifter sticks up through the trans tunnel. :thumbsup: Link to comment Share on other sites More sharing options...
