Huntingman2706217 Posted June 27, 2010 Share Posted June 27, 2010 got a 4.0/AX-15/231 short bed setup... SOA D35... need some driveshafts... i think I'm good on the front driveshaft as it should be the same as a XJ and i have one of those... the rear is the tricky one... i can't find a 4x4 MJ in any of the local yards... and id rather not build one if i could help it... thanks! Link to comment Share on other sites More sharing options...
Unglar Posted June 27, 2010 Share Posted June 27, 2010 Can you use the stock axle when you go SOA? Link to comment Share on other sites More sharing options...
Huntingman2706217 Posted June 29, 2010 Author Share Posted June 29, 2010 probly... but i swapped to 4x4 also from 2x4... so it won't work for me... have to cut it down... Link to comment Share on other sites More sharing options...
Bounty Hunter Posted June 29, 2010 Share Posted June 29, 2010 Most driveshaft shops will shorten and balance a driveshaft for under $100. Link to comment Share on other sites More sharing options...
Unglar Posted June 29, 2010 Share Posted June 29, 2010 Can you use the stock axle when you go SOA? Doh! I meant drive shaft... glad you all are smart enough to realize that. :-) Link to comment Share on other sites More sharing options...
Huntingman2706217 Posted June 29, 2010 Author Share Posted June 29, 2010 Most driveshaft shops will shorten and balance a driveshaft for under $100. i could shorten it myself... its not that hard... but its easier just buying a OEM one... and be done with it... found a long bed MJ still with the driveshafts in my JY... but its not a short bed dang it!... good news is they got a 99 XJ in and i need the fenders... lol... STILL looking for a driveshaft!!! Link to comment Share on other sites More sharing options...
