5 spd hydrolic fluid leak
i was in the process of replacing my clutch in my 86 with a 2.5. not sure what tranny. anyways, i put the new clutch in and had everything together when i went to bleed the clutch. when i was pumping the clutch pedal there was NO pressure at all. while the pedal is being pumped you can see fluid run out from the clutch/bell housing. any ideas?
86 is external slave. There should be NO fluid inside the bellhousing. Your slave cylinder is located on the passenger's side of the bellhousing. If there's a leak, it's coming from there, or you blew a hole in the hose and it's dribbling down the housing. It's not that hard to pinch the line between the bell and the motor when you're putting the trans back in.
