MJ is dead Posted June 14, 2010 Share Posted June 14, 2010 Will it work? I have no front bumper...well no real one. 2x4 doesn't count Since I wanna do the 97+ swap someday, I just wanna buy the bumper now to save some pennies. Will it work no prob? I have the original 10 slot front end right now Link to comment Share on other sites More sharing options...
Jeepman Posted June 14, 2010 Share Posted June 14, 2010 The Bumper will fit but in order to use the end caps you will have to cut your fenders as the newer caps wrap around the corner... Link to comment Share on other sites More sharing options...
MJ is dead Posted June 15, 2010 Author Share Posted June 15, 2010 Alright. I have no problems with taking a sawzall to the ole MJ :D Link to comment Share on other sites More sharing options...
Jeepman Posted June 15, 2010 Share Posted June 15, 2010 Once you install the Newer bumper and end caps you more then likely want to install the front flares but if not you will need to cut the flares as well... Good luck it should look nice with the old header panel and Newer bumper... Link to comment Share on other sites More sharing options...
