zzze Posted May 11, 2010 Share Posted May 11, 2010 with my new 1988 4.0 L renix 5 speed i just got about a month ago i have a pretty good exhaust leak... the fumes enter my cab so i have to keep the windows open at all times. i have not had the time to find the leak but if it is bad enough where should i go to find replacement parts for the exhaust? Link to comment Share on other sites More sharing options...
dasbulliwagen Posted May 11, 2010 Share Posted May 11, 2010 You probably have busted exhaust manifold studs at the very front and very rear of the cyl head. It is very common and Chrysler has a tech bulletin for this with new studs, nuts, torque value and a plastic spacer. Either that or your EGR tube gaskets have gone bad, or like my truck, and have the Crankcase fumes running in a tube dumping out under the truck before they make their way back into the cab! Link to comment Share on other sites More sharing options...
one_bad_MJ Posted May 11, 2010 Share Posted May 11, 2010 was this tech bulletin a recall? Link to comment Share on other sites More sharing options...
dasbulliwagen Posted May 11, 2010 Share Posted May 11, 2010 No I don't think it was ever a recall, because it wasnt that much of a safety issue. Link to comment Share on other sites More sharing options...
