88pioneer Posted May 10, 2010 Share Posted May 10, 2010 pulled my rear shocks to measure for new ones. I got right around 22.5 inches for extended and 14 for collapsed. They seem a little short, but i'm not sure. Its on a spring over, sits right around 5 inches right now Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted May 11, 2010 Share Posted May 11, 2010 Its on a spring over, sits right around inches right now Think you forged to type the #.... Let me know height and how you currently have your shocks configured (factory mount setup, still using the lower mounts in the same place; or did you move them higher?) and I should be able to give you a good range that'll work. Link to comment Share on other sites More sharing options...
88pioneer Posted May 11, 2010 Author Share Posted May 11, 2010 woops, 5 inches. it looks like the lower mounts are still in the old position. The top mounts look to be the same distance away, but instead of being mounted in front of the axle, they are behind the axle, towards the bumper Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted May 11, 2010 Share Posted May 11, 2010 I'd probably go with a 12" travel shock if it was me. Ext. - 30" Col. - 18" Link to comment Share on other sites More sharing options...
