lights dont work
Yep my guess could be faulty ground as well.
I found that following the wires usually leads me to the problem. Not too long ago I discovered a bad turn signal socket and two bad flashers and that the trailer wiring harness under my box was so corroded that it was interfereing with my rear marker lights. All you can do is start from the light socket and work your way back.
