Dana 42L PTO?
dunl
Looks like it's from any of the GM SM460 trannies, Will also fit any 4-5 speed , Ford, IHC, Jeep with proper spacer. Late '30's to mid '70's.
So it could possibly run on a GM sm420?
And what do you mean by spacer....adaptor?
Yep. Different transmissions had had different gear sizes on the main shaft, which is where that big gear sticking out goes. With the smaller gears the PTO would fit flush againest the trans case. With larger gears the PTO would sit out away from the case. It needed a spacer to get the proper clearance.
