wiring
this is a new installment of a old topic. today i sorted out a last problem with the new wiring and it started and runs :brows: greeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeat!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :brows: :banana: :banana: :banana: :banana: :banana: :banana: :drool: :drool: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf:
two things i learned. remove the grounds from the engine block, thats next to the oil filter and clean them for good contact. the other, remove the plugs from the computer and spray contact cleaner on the male and female terminals. let soak, then take them in and out a few times. let dry throughly, then reinstall. as a maintenance tip this could or will help drivability problems :D
