sinkrun Posted April 7, 2010 Share Posted April 7, 2010 Any of you guys have any tricks for removing broken off grill screws from the front header? Link to comment Share on other sites More sharing options...
MJ300 Posted April 8, 2010 Share Posted April 8, 2010 Been there plenty of times. What I normally do is grind the screw flat, center punch it, then drill it out. Then take a hard epoxy of some type and plug up the hole where you drilled out the old screws. After the epoxy has hardened drill a hole in the center a bit smaller than the screws and your back in business. A bit time consuming but works very well. :cheers: Link to comment Share on other sites More sharing options...
Backroads Posted April 8, 2010 Share Posted April 8, 2010 tried that the other day, its hard to grill them out nicely without botching up the fiberglass surround. I still need to find my trick. Link to comment Share on other sites More sharing options...
