LSD pre-mix
Looking on the shelf at gear lube I notice that some of the containers say LS, for Limited Slip Differentials.
Can I trust the pre-mix or should I just buy regular gear lube and add the friction modifier myself?
D44 LSD
You have to read the container.
Years ago, the Castrol I was using said "for limited slips", then the back of the container said:
"good for topping off", or something to that extent.
Meaning: if you already have an axle, with the friction modifier in it, and it's low, use this stuff.
Personally, I would only trust it if it said "includes friction modifier".
