taillight harness question
swapped a 1986 box on my 87, they cut the wires. I kept my old harness, and there was a round hole going through the sheet metal that hangs behind the bed, anyone know the diameter? Apparently 86 used a different location! Just wanna make sure I cut the right size hole!
THanks
Tom
Are you asking about the hole in the rear apron of the bed, like under the tail gate???
I just pulled a wire harness off a '88 bed the other day, I can check the diameter of that hole for you, where the wire grommet goes in :brows:
I'll post up tomorrow night ;)
