TooTall Posted March 2, 2010 Share Posted March 2, 2010 I have a 1988 4.0 with a B-10 Peugeut that I am taking out and replacing with 1992 Commanche ax/15. In the process of replacing I noticed pilot bearing for B-10 was smaller in inner diameter. I purchased 1992 Commanche pilot bearing for ax/15 but outer diameter is smaller and fits loosely in engine. Noticed when I took out the other bearing there was a steel sleeve around it. If I were to attempt to fit this bearing I would need a very thin sleeve. One advice stated that a CJ pilot bearing for the 304 would fit. Does this bearing have rollers or just a brass sleeve. Does anyone else have any suggestions in regards to what might work. Link to comment Share on other sites More sharing options...
Pete M Posted March 2, 2010 Share Posted March 2, 2010 The CJ has a bushing, not a bearing. :thumbsup: Link to comment Share on other sites More sharing options...
TooTall Posted March 2, 2010 Author Share Posted March 2, 2010 so will the bushing from a cj work or what do i need????????this is a hangup! Link to comment Share on other sites More sharing options...
Pete M Posted March 2, 2010 Share Posted March 2, 2010 Yes, it should work. Mid 70s CJ with a 304/manual trans. It's a $2 part. :thumbsup: Link to comment Share on other sites More sharing options...
TooTall Posted March 2, 2010 Author Share Posted March 2, 2010 thanks greatly appreciated i guess the roller type isnt a biggy not haveing it? Link to comment Share on other sites More sharing options...
Pete M Posted March 2, 2010 Share Posted March 2, 2010 either type works fine. :thumbsup: Link to comment Share on other sites More sharing options...
