So lately I've been trying to figure out how to classify the renix o2 sensor. It didn't register before that it operated on a 5v range when I'd only heard of 1v range sensors. Since some wideband o2 sensors use a 5v output does that mean the renix sensor qualifies as a wideband sensor? Or was it not that sensitive and needed the extra voltage range to make up for it? It'd be nice if a could hook up an afr gauge of some sort directly to the factory o2 sensor. Has anybody ever logged the voltages produced while a stock (or non stock) motor was running?
