Are the fuel tank rollover valves/vent valves interchangeable between the XJ and MJ (specifically 1990)? I discovered my tank is holding a lot of pressure and apparently neither vent valve works. I pulled a set of vent valves from a '90 XJ that work fine (vacuum tested both) and they look like they'll fit. I know the tanks & sending units are different so before I drop the tank again I wanted to confirm they would, in fact, be a direct replacement.
The 90 XJ & MJ vent valves have the same part numbers, so I'd say yes. :cheers:
