The ole MJ doesn't like the cooler mornings
4.0 cranks but doesn't turn.
just about ready to give up, it turns over.
then, it is revving high, for about 4-5 minutes.
I changed the fuel filter and plugs.
air filter is fine, fuel is fine, battery is fine.
any ideas fellas?
...BOB
Also check the water/air temperature sensors, their job is to tell the computer that the engine is cold, and the cold outside air temp.
The computer use these inputs to give the engine a rich gas-mixture needed in cold weather. (as the choke on a carb engine).
The computer also tells the IAC to open and pass more air to the engine, in order to increase the cold idle rpm.
