Rattling Clutch
I get a loud rattle in 3rd 4th and 5th. It goes away if I push in the clutch and when I give it gas. I recently replaced the clutch. Anyone have experience with the wrong, or a faulty, clutch being installed?
86 4cyl with Ax-5 trans.
Is it supposed to have an external slave with a spacer?
did you replace the throwout bearing and the pilot bearing? both will give you the problem you describe when they are wore out. :(
yes there is a spacer on the external slave on my 86 XJ and MJ. :hmm:
but my 90 MJ and 88,89 XJs have internal slaves :dunno:
I installed the correct clutch 9 11/16" it came with a small plastic spacer that goes on the end of the slave cylinder push rod. didn't remember that during disassembly but it won't disengage without it?
I thought surfacing the flywheel would take care of the rattle, I am wrong and disappointed.
I still have a rattle only when just letting off the gas in 3rd 4th and 5th. I stayed in 2nd and ran the RPM's high and didn't get a rattle but a whine. I am therefore thinking it is a bearing. The truck has 300k miles on it, supposedly the engine has been rebuilt. I don't think the trani has been touched.
All I can think is the bearing on the input shaft.
The list.
1. Rebuilt the rearend.
2. New U-Joints.
3.New (correct) Clutch.
Surfaced the Flywheel.Friction,Pressure,pilot and throwout new.
