mjeff87 Posted September 27, 2006 Posted September 27, 2006 I think I might devote this weekend to the MJ, finally. Among other things (b-pillar lights, vac disco) I might start to rig up the mechanicals for OBA on my non-AC 2.5L, but I have a couple questions: anyone here run OBA with a stock Sanden compressor on a 2.5L? pics? what would be a good place to mount a tank? what size tank and what pressure would be good for a small impact wrench? Other than that, I'd just be using it to fill tires and such. TIA, Jeff
JOMJ87 Posted September 27, 2006 Posted September 27, 2006 check out my tank mounting and the discos on the bed rails i just got to buy a bigger tank to help out. http://comancheclub.com/forums/viewtopic.php?t=1217 Cole
mjeff87 Posted September 28, 2006 Author Posted September 28, 2006 Thanks for the pics :cheers: I'm still not sure about the tank, tho. I'd like to mount it up under the bed somewhere, or behind the rear bumper where the spare tire used to be (until I sawzalled all that out :brows: ) Image Not Found I picked up a 2.5 alternator/compressor mounting bracket from Chuck yesterday, and my friendly neighbor is sandblasting it for me today at work. I'm'a run down the junkyard Saturday morning and grab a compressor and get at least the mechanicals mounted up this weekend (compressor, new belt, new upper rad hose). Then I'll plumb it all and install the tank. Jeff
JOMJ87 Posted September 28, 2006 Posted September 28, 2006 You could take some pipe and cap it off and put 2-3 tubes in that hole and plumb them together. :dunno: Cole
