JOMJ87 Posted September 26, 2006 Share Posted September 26, 2006 Which one is my motor I have a 87 Sport truck 4X4 and yes it is a 2.5 and i like it :eek: it does just fine and i don't want to deal with a engine swap. Plus i just am curious i may still swap since i can get an automatic 4.0 for real cheap. I just don't want to deal with the wireing But who knows i gotta keep my options clear. Cole AMC 2.3 140 4 Willys 1959 $1,890 $500 $195* AMC 2.5 150 4 U,H - 83-87 83-87 Eagle, 83-86 Jeep, 7/16" Head bolts, Block #448, 059, Head #893, Crank#611, oil filter bypass in block, mechanical FIR Can use DA27 DA"24 $1,190 $300 $195* AMC 2.5 150 4 U,H - 86 Block #059, Head #403, Crank #611, 1/2" head bolts, with oil filter by-pass in block DA27 $1,190 $300 $195* AMC 2.5 150 4 H,P - 87-97 Block #200, 059, 532, 403, Head #403, 117 Crank #904, Crank snout 2.125",Oil bypass in filter, not in block, FI only DA28 $1,190 $300 $195* AMC* 2.5 151 4 B - 82-83 Pontiac Engine Jeeps and Eagles. Block #152, Head #552, 702 specify stud mount or bolt on rockers DA25 $1,190 $300 $195* AMC* 2.5 150 4 H,P 98-00 Block #200, 059, 532, 403, 117 Crank # 904, Crank Snout 2.125", Oil Bypass in Filter, Not In Block, FI Only. Wrangler DA36 $1,290 $300 $195* Link to comment Share on other sites More sharing options...
Eagle Posted September 26, 2006 Share Posted September 26, 2006 AMC 2.3 140 4 Willys 1959 $1,890 $500 $195* NOPE AMC 2.5 150 4 U,H - 83-87 83-87 Eagle, 83-86 Jeep, 7/16" Head bolts, Block #448, 059, Head #893, Crank#611, oil filter bypass in block, mechanical FIR Can use DA27 DA"24 $1,190 $300 $195* NOPE AMC 2.5 150 4 U,H - 86 Block #059, Head #403, Crank #611, 1/2" head bolts, with oil filter by-pass in block DA27 $1,190 $300 $195* Probably not, but might work AMC 2.5 150 4 H,P - 87-97 Block #200, 059, 532, 403, Head #403, 117 Crank #904, Crank snout 2.125",Oil bypass in filter, not in block, FI only DA28 $1,190 $300 $195* Sounds good AMC* 2.5 151 4 B - 82-83 Pontiac Engine Jeeps and Eagles. Block #152, Head #552, 702 specify stud mount or bolt on rockers DA25 $1,190 $300 $195* NOPE - this is the Iron Duke, which AMC bought from Pontiac for some vehicles AMC* 2.5 150 4 H,P 98-00 Block #200, 059, 532, 403, 117 Crank # 904, Crank Snout 2.125", Oil Bypass in Filter, Not In Block, FI Only. Wrangler DA36 $1,290 $300 $195* Newer, but I don't know why it wouldn't work, except the manifolds will be different. Your '87 has the Renix throttle-body injection. Anything for '91 and newer will be set up for the Chrysler multi-port injection. The basic short block *should* be the same, but externals and manifolds will be different. Link to comment Share on other sites More sharing options...
JOMJ87 Posted September 26, 2006 Author Share Posted September 26, 2006 Thanks alot for the quick reply i was thinking the one you said is prob it but i didnt want to be wrong. Ill keep this info for later thanks again. Cole Link to comment Share on other sites More sharing options...
