Wiring harness for Power windows/doors 91 plus
johnj92131
I had trouble finding mine for the 88. Ended up using a 4dr door harness and moved some of the wires around in the plug to make it a 2dr. Basically if I remember right it was two wires. Should be a similar fix for the HO era.
:cheers:
:cheers:
I found several 88-90 and a 94 on Saturday, all from 2 doors. but no 91-93. I will keep looking a little longer - then I will make the 4 door harness work.
