88mjmanche Posted December 16, 2009 Share Posted December 16, 2009 where do you check the fluid level on a BA/10???? a pict would be really nice Link to comment Share on other sites More sharing options...
XXLMJ Posted December 17, 2009 Share Posted December 17, 2009 There is a plug on the passenger side about half way up. It looks like a 3/8 would fit in the square hole, but it won't. I took and broken 3/8 extension and used a hand grinder to cut it to the size. Then you have to pump the oil in, i used the same pump i use to put the oil into the lower unit of my boat. The plug is round bout a 1".5 around and almost right above the cross member. Link to comment Share on other sites More sharing options...
88mjmanche Posted December 17, 2009 Author Share Posted December 17, 2009 sweet deal thank you Link to comment Share on other sites More sharing options...
