ZJ power steering pump and box
I know the box will work on a mj, but what about the pump.....donor zj is a 96 with a v8.
Would be going on a 4.0??? Thanks
They are both Saginaw TC pumps, so it should mount okay. Most differences in these pumps were in the tank hose fitting angles and the output pressure. I have an 04 TJ pump on mine w. a ZJ box and everything fit fine. Worse case you may have to reuse the old reservoir.
