front axle carrier bearing cap torque?
I found two different specs on the front axle(D30) carrier bearing cap torque, the cherokee forum says 40 ft lbs and here it says 57 ft lbs...???? Which is correct? I just converted a friends disco axle to non-disco w/ solid passenger side axle shaft swap and need to re-torque the carrier. Thanks
-Lance
