Emergency Brake relocation
I did some years ago with an MJ I don't have anymore. IIRC I used the stock length cable. I looped it to take the slack out. I don't remember where the loop was (I think maybe on the cab floor under the carpet), but as long as you keep the bend radius of the loop as large as you can the cable won't bind. Maybe not the best permamant solution, and I'm sure there will be nay-sayers, but it worked fine for me.
