Accomplished a few things this weekend!
GreenF350
First off, Ive been wanting to address the frame rot that I knew was hiding under there, so the bed had to come off. Since the bed was really just a patch job that was rotting too, it went to the crusher. I got all the stuff i needed off of it first though.
Next off,a picture of the rot..
And the other side getting patched......I still have some grinding to do..
I plated the inside of the frame rail with steel and built up the weld on the outside, and am in the process of grinding it flush. You can see the finished product above the tire where its bare metal. Should work out. Anyways,from here I plan on going through the whole truck once again, but I plan on taking pictures this time :D
