smithe1811 Posted November 11, 2009 Share Posted November 11, 2009 What are the symptoms of a bad torque converter on a 97Zj, 4.0 part time 4x4. whats its doing right now is sometimes when i let off of the gas to slow down, it lurches a little and under acceleration first gear is sluggish, almost like there is low tranny fluid which is not the case. Erik Link to comment Share on other sites More sharing options...
underdog Posted November 25, 2009 Share Posted November 25, 2009 I had the same issues in the beginning of the end of the transmission in my ZJ. After that it would not shift out of 1st gear until it was completely warm. The tranny guy I use says that the pressure switches in them go bad and it keeps the selanoid valves stuck part way open or shut. Something along those lines. I have one in the garage for a 4.0L that came from one I parted out a while ago. Link to comment Share on other sites More sharing options...
jeepdoggydogB Posted November 26, 2009 Share Posted November 26, 2009 In my old 97 I had a power/comfort switch, if it lurches in both modes I would think the transmission is in need of servicing. Also if you have the select trac transfer case sometimes getting out of 4WD can be a booger. I used to have to drive backwords for a bit to get it to disengage. Link to comment Share on other sites More sharing options...
