Weezel Posted September 11, 2006 Share Posted September 11, 2006 I have a minor issue with my wiring, i did my trans/case swap today and ran into a little problem. my 91 2wd mj speedo wiring is different from my 94 xj aw4/231 combo here is the colour scheme for the wiring: plug on 91 2wd aw4: 2 wire> white/orange stripe black/blue stripe plug on 91 body harness: 4 wire> white/orange stripe black/blue stripe black/red stripe black/grey stripe plug on 94 aw4/231: 5 wire> orange black white/orange stripe black/blue stripe black/red stripe also on my 91 body harness a couple of inches from the 4 wire plug the is a 2 wire plug> red/black stripe black does anyone have a diagram or the knowledge to help me sort this out. thanks W :Canadaflag: Link to comment Share on other sites More sharing options...
jeepthing07 Posted September 11, 2006 Share Posted September 11, 2006 Why can’t you just swap the speed sending unit/gear thing over from your old case? There’s just 1 bolt holding it in should be a direct swap :Edit: Now I see that its a 2wd to 4wd swap sorry... the cable driven sending unit on my 2wd AX5 looks a lot like the one in my cable driven NP231 I haven’t looked at both of them closely though. Maybe my original idea might work? It’s worth a shot anyways. The extra wires on the later years might be to keep the odometer from going backwards when backing up Link to comment Share on other sites More sharing options...
Weezel Posted September 11, 2006 Author Share Posted September 11, 2006 both transmissions are electronic speedo's its just a matter of me splicing in the plug from the 94 harness to the 91 harness. i just don't know what all the wires do!! if i cross reference a 91 FSM with a 94 FSM ill have it all figured out... only i don't have them! W :Canadaflag: Link to comment Share on other sites More sharing options...
Weezel Posted September 12, 2006 Author Share Posted September 12, 2006 Anyone?.... i guess it is not a bolt in/plug in procedure. W :Canadaflag: Link to comment Share on other sites More sharing options...
Weezel Posted September 12, 2006 Author Share Posted September 12, 2006 ok could someone tell me what colour the wires are coming out of a 231 on a 91 mj? or if there is one plug or two plugs or what.... thanks W :Canadaflag: Link to comment Share on other sites More sharing options...
