jackel18 Posted September 9, 2006 Share Posted September 9, 2006 i was just wondering if a wrangler trans/t-case will fit in a comanche? the engine will bolt right up if its a 4.0 right? Link to comment Share on other sites More sharing options...
Bounty Hunter Posted September 9, 2006 Share Posted September 9, 2006 Everything will bolt in among similar model years, but the YJ clocks the transfer case up higher, possibly causing chassis clearance issues on the MJ. Link to comment Share on other sites More sharing options...
ejndssn Posted September 10, 2006 Share Posted September 10, 2006 its sure does and it hits the underside some I'm in the process of swapping it out again with a cherokee with an external setup! Link to comment Share on other sites More sharing options...
