azscott Posted October 17, 2009 Share Posted October 17, 2009 Arghhh...had no isue the first month...now....? The last couple of days it has been a little hard to start. Sometimes it will start ...idel rough and then stall. Or just idle rough for 2-3 minutes. It accelerates fine...but will stall or almost stall for the first 1-2 minutes on startup?. Seems to only di this if warm or hot. When it sits all night no problems starting...so far. If I stop for 10 minutes or so and get back in it is more likely to do it....although sitting for an hour or two will also. Runs fine other than that. I checked for vacuum leaks but that should cause a high idle I would think...but anyway...none were found. TPS was adjusted a month ago but it was fine as was the other idle thing next to it( name escapes me. MAP seems to work fine and tested fine. I still plan on replacing the O2 after some recoomendations for the low idle as I have no ideas left on that. But now this hard starting/rough idle for the first 2 minutes it starts has become an issue all of a sudden. What would be the logical approach to this. I love the truck...runs great overall...even with the Puegot tranny ( hey what can ya do. again this is an 89, 4.0 5 speed. ( I will put that in my signature shortly) scott Link to comment Share on other sites More sharing options...
64 Cheyenne Posted October 17, 2009 Share Posted October 17, 2009 I would check for fuel pressure at the fuel rail first, probably after it sat for 10-15 minutes. If that was good, I would either unplug/plug the CPS, see if that helps, or replace the CPS. Link to comment Share on other sites More sharing options...
azscott Posted October 17, 2009 Author Share Posted October 17, 2009 I can check that. But wouldn't the problem be worse when it sat overnight if theere was a fuel pump pressure problem? Or am I looking at it wrong. I will pick up a fuel pressure test kit later today as I wanted one anyway. scott Link to comment Share on other sites More sharing options...
