rejeep Posted September 5, 2006 Share Posted September 5, 2006 blew the H20 pump on my 86 2.5 today... the bearing siezed and the pully was shaking all over... are these water pumps the same as the 6 cyls.. I must have 10 of thoes laying around? Link to comment Share on other sites More sharing options...
feerocknok Posted September 5, 2006 Share Posted September 5, 2006 1986 JEEP COMANCHE XLS L4 2.5 Liter FI Cardone Water Pump: Remanufactured; w/o Serpentine Belt Part Number: 58103 1986 JEEP COMANCHE XLS V6 2.8 Liter 2BBL Cardone Water Pump: Remanufactured Part Number: 58159 1988 JEEP WRANGLER SAHARA L6 4.2 Liter Carbureted Cardone Water Pump: Remanufactured; W/O Serpentine Belt Integral Pipe Part Number: 58103 1988 JEEP WRANGLER SAHARA L6 4.2 Liter Carbureted Cardone Water Pump: Remanufactured; W/O Serpentine Belt Non-Integral Pipe Part Number: 58354 1988 JEEP WRANGLER SAHARA L6 4.2 Liter 2BBL Cardone Water Pump: Remanufactured; W/O Serpentine Belt Integral Pipe Part Number: 58103 1988 JEEP WRANGLER SAHARA L6 4.2 Liter 2BBL Cardone Water Pump: Remanufactured; W/O Serpentine Belt Non-Integral Pipe Part Number: 58354 Depends. Link to comment Share on other sites More sharing options...
87manche Posted September 6, 2006 Share Posted September 6, 2006 I believe that the rotation on those pumps is different. Look at the impellers. The 4.0 uses a reverse rotation pump because of the serpentine belt. Link to comment Share on other sites More sharing options...
rejeep Posted September 7, 2006 Author Share Posted September 7, 2006 yeah mines a V belt.. I think ill splurge the $30 and buy a new one.. is just the gasket ok, or do i need RTV? Link to comment Share on other sites More sharing options...
Oizarod115 Posted September 7, 2006 Share Posted September 7, 2006 jeepin.com did a write up of an install on one. i used blue rtv along with the gasket like they did. you might need a pipe wrench to get the long skinny tube out of the old one. (mines an 89 though) Link to comment Share on other sites More sharing options...
feerocknok Posted September 7, 2006 Share Posted September 7, 2006 Just put mine on last week. We cleaned the block off (new block, but it had paint on it), put high temp gasket sealant on one side of the gasket, then on the block, then put the gasket on the block, the put gasket sealer on the second side of the gasket (the side facing the world), then gasket sealer on the water pump, then mounted the water pump. Link to comment Share on other sites More sharing options...
