front end shaking....I give up....update 10/15
Seems tire balance is part of the problem, but not the whole story. You have at least one worn part on your front suspension that needs to be replaced. You can take a week to take everything apart and inspect it all, or just start throwing parts at it until you find it. Third option is to keep your speed below 65 and ignore it, but the problem will probably get worse until eventually hopefully it will be obvious what part(s) is/are to blame.
When I say everything I mean literally everything. Strip it down to the tie rod ends and ball joints.
