thejum57 Posted October 10, 2009 Share Posted October 10, 2009 Could a bad starter make the "battery" light glow sometimes? It's usually off, but sometimes it will glow, then go off. When the battery needed to be replaced it came on as soon as I started the truck and stayed bright till I got home. Link to comment Share on other sites More sharing options...
Automan2164 Posted October 10, 2009 Share Posted October 10, 2009 Bad starter will not make the battery light come on. It comes on when it sees too much, or most likely in your case, too little voltage. Check the connections from the alternator to the battery, and make sure that alternator is cranking out some volts. Rob L. Link to comment Share on other sites More sharing options...
mvusse Posted October 10, 2009 Share Posted October 10, 2009 Are you sure about the voltage? I though it read the direction of the current, and came on whenever the battery was being discharged. As in more power is being used than the alternator is delivering. Link to comment Share on other sites More sharing options...
thejum57 Posted October 24, 2009 Author Share Posted October 24, 2009 Finally broke down and brought it to a shop for a diagnostic. They tested the batt. & alt. Said they were both good. Said it's probly all the oil leaking on the connections & the starter. Wanted to rebuild the entire truck, I said "how much do I owe you" :cheers: Replaced the starter today....what a pain that was. Turned the key and it fired up like a new truck. Valve cover gasket is next, then some engine de-greasing. Link to comment Share on other sites More sharing options...
