Yet another gear ratio quetsion
Mosst likely 3.07. You can check yourself, usually there is a tag on the passenger side of the differential cover, and there should be a bunch of numbers, but there will be a few kinda set off from the rest, and have the first number followed by the second. it will look like >>>
. bolt 878716845531 bolt .
..................64453 3 . 07.................
Numbers I put in are just crap, but you get the idea.
Oh, and it helps when you try to read this if your truck never spent time in the rust belt.
Rob L.
