Guest guest Posted August 30, 2006 Posted August 30, 2006 are the doors off of an xj the same as the doors on an mj
sinnaevd Posted August 30, 2006 Posted August 30, 2006 on a 4 dr cherokee yes they are, minus the little triangle window pieces which leak like a siv n e way...
mjeff87 Posted August 30, 2006 Posted August 30, 2006 Only up to 96 will swap directly. 97+ models are redesigned a bit, and take some fabrication to install. Jeff
87manche Posted August 30, 2006 Posted August 30, 2006 Only up to 96 will swap directly. 97+ models are redesigned a bit, and take some fabrication to install.Jeff http://www.naxja.org/forum/showthread.p ... =door+swap :D
