Clutch pedal fade.
Since I had the clutch master replaced on my 87' I have noticed the pedal get soft under frequent use like heavy traffic but it returns to normal after a few seconds of not being used. What could be causing this? Do you think they didn't bleed the system good enough and the is air trapped in there? 1987 2wd 4cyl 4speed.
Your guess about air in the lines is probably correct, based on what you described, as for the shudder this is a sign that the tranny is wearing. Check the fluid levels and add a sysnthetic such as lucas or royal purple they may help the tranny survive a little longer.
