i was thinking about ordering replacement rockers from shermanparts, but there is also the cab corner that i have to patch up, I'm wondering how far back the replacement rockers go, if anyone has a picture of them and where they start/end i would be greatful, also if anyone has any suggestions on ways to repair cab corners like a replacement or a method any help would be apreceated.
Jonathan
cab corners are tough to get looking good.
You'll need a prebent pice to fit.
I don't think anyone is making replacement cab corners, best bet is to see if you can't source a junkyard beast with decent metal and cut it out.
Make sure you cut it bigger than your patch, an I mean a lot bigger.
You'll end up cutting out 2-3 inches from the rust spot to find good clean metal.
