buddy208 Posted July 29, 2009 Share Posted July 29, 2009 i just swap every thing from a 94 cherokee to a 89 cherokee and we are working on the rear end wiring and when we hook everything up the head lights and brake lights did work can anyone tell me why or if it could be a fuse. Link to comment Share on other sites More sharing options...
buddy208 Posted July 30, 2009 Author Share Posted July 30, 2009 one more thing the brights come on but don't stay on Link to comment Share on other sites More sharing options...
Wildman Posted July 30, 2009 Share Posted July 30, 2009 '94 = Chrysler '89 = Renix era (AMC) Unless you replaced the rear harness with the newer one, there could be a crossed wire in the connector, you really need to check the FSM's from both, and cross check, wire color (termination) and terminal location. The dimer switch in on the steering column, left upper side, just behind the knee panel, the switch could be shot, or you might need to change over the dimmer switch. I'll get this wrong., I think.......but Chrysler went to a Positive ground system, were Renix is a negative ground system.......or did I get that backwards again :hmm: Anywho, all the switches need to be change over to which era you want to end up with. Link to comment Share on other sites More sharing options...
buddy208 Posted July 30, 2009 Author Share Posted July 30, 2009 yea we hook up the rear harness the lights still did not work Link to comment Share on other sites More sharing options...
Wildman Posted July 30, 2009 Share Posted July 30, 2009 yea we hook up the rear harness the lights still did not work You swapped the rear harness from the '94?? Check where the body ground is in the rear, that could be your problem. Also check the body/engine ground. Link to comment Share on other sites More sharing options...
