sinkrun Posted July 13, 2009 Share Posted July 13, 2009 I removed and shimmed the CAD today. I checked and filled the oil at the pumkin is this good or is there an area to fill at the CAD area? Link to comment Share on other sites More sharing options...
Automan2164 Posted July 13, 2009 Share Posted July 13, 2009 The differental level should bleed over to the CAD area. When you took of the CAD, you probably lost a little, not much. It might take a bit for it to work its way over to the CAD. I would make sure the level is good, drive it for a day, and check it again. After that, I wouldn't worry about it. Rob L. :thumbsup: Link to comment Share on other sites More sharing options...
sinkrun Posted July 13, 2009 Author Share Posted July 13, 2009 Thanks for the help will check it again in a day or two. Link to comment Share on other sites More sharing options...
Geonovast Posted July 14, 2009 Share Posted July 14, 2009 With the CAD system disabled, you shouldn't need a lot, if any, fluid over there anyway since the collar will no longer be moving. Link to comment Share on other sites More sharing options...
