jeep comanche running gear question
The engine can be made to work with the ZJ harness, although it's not going to be easy.
The front axle will bolt directly in, however ZJ D30s are low-pinion, and it will actually be a downgrade for you.
The rear axle is not even worth it. ZJs have coil and link rear suspension, so the axle would need a decent amount of work to make it fit in your MJ. D35s and ZJ D44s are not worth the trouble.
Honestly, you will be better off finding a complete XJ for a donor. Front axle is a much better option, for the most part the wiring is going to be a direct swap (since XJ and MJ engine bays/dashes are the same), and fiddling with the rear axle will be easier.
Something you may want to consider though... Since your MJ is a 4 cylinder, it probably has lower gearing than the 6 cylinder donor would have. If you're going with any sort of lift or larger tires, you'll probably want to keep your existing axles. If you have a 2.5/4 speed now, and you go with a 4.0/auto donor, chances are pretty good the gearing will be the same. (3.55)
Broken down, really the only thing feasible to use from a ZJ is the longblock unless you have too much time on your hands.
