HOrnbrod Posted July 13, 2009 Share Posted July 13, 2009 thought they said it would be okay, but short term memory full, so will recheck. i keep going out of town, so haven't done anything for over a month on it. The Rampage lamps are okay for use as direct replacements for the factory driving lamps. If you didn't use the Rampage lamps to replace factory lamps, most of the wiring is already there in your existing harness to utilize. Basically all you have to do is wire in the relay and trigger it with the switch. I can send you a wiring diagram how to do this if you want to make it right. :D Link to comment Share on other sites More sharing options...
