power seats?
i havent, but it would be the same process as manual seats. they mount the same. you would just need to run a power and ground wire to get power to the plug on the power seat. put it on a relay and it should work good.
Actually, the pedestal of the XJ power seat is quite massive and you'll need it to retain the power option. It doesn't fit well on the MJ floor. I'm not saying it's impossible, but it's not as easy as the manual seats where it's no biggie to reuse the MJ floor pedestal.
