Dave88 Posted July 2, 2009 Share Posted July 2, 2009 my parking lights are dimming with my dimmers switch and my dash panel lights are staying on all the time and killing my battery i'm am at witts end. does anyone have any idea what i should look at first. :( :( :fs1: Link to comment Share on other sites More sharing options...
Geonovast Posted July 2, 2009 Share Posted July 2, 2009 I had an 89 XJ that had similar problems. Is yours an automatic or manual? My XJ's clutch master had a bad leaking problem and destroyed the fusebox, causing all kinds of cross circuits and weird shorts. Link to comment Share on other sites More sharing options...
vaquaro Posted July 2, 2009 Share Posted July 2, 2009 Connector block into H/L switch (look for burn/melting between ports ) then trace back loom ,especially over e-brake to firewall . Same for fuse-block thru firewall connections often short due to water or brake fluid dripping down from above . Good luck :shake: Link to comment Share on other sites More sharing options...
Dave88 Posted July 2, 2009 Author Share Posted July 2, 2009 thanks will do sounds like good advise it's an automatic :cheers: Link to comment Share on other sites More sharing options...
Dave88 Posted July 3, 2009 Author Share Posted July 3, 2009 well, I'm breaking stuff on the truck trying to figure out what is wrong with it now. i cleaned all the connection boxes. i thought it was the headlight switch at first but i took it out and my instrument cluster lights are still on and they won't shut off no matter what unless i take out the fuse... any ideas? Link to comment Share on other sites More sharing options...
