Front axle non disconnect swap
I'm in the middle of swapping a single piece passenger side shaft into my vac disco axle housing. According to Autozone as well as Advance Auto Parts, for a non-disco housing the passenger and driver side seals are the same. Went to install it and no go.
The Timken/Mational 710068 seal has an outside measurement of 2.128" designed to fit into a 2.122" shaft. That works on the driver side of a vac-disco housing, and either side of a non-disco housing.
The vac-disco housing passenger side tube is smaller, though. Supposedly NAPA 11800 (2.004") or NAPA 11771 (2.000") will fit. Don't know what Timken/National part number they cross reference to.
:wall:
when i did this on my mj i used a dremel and ground down the passenger tube in the diff so that a stock seal would fit. it was a pain and it took forever but i feel its worth it. the stock seal has a little ramp built into it to guide the axle shaft in to help keep from damaging the seal when installing the axle.
