Casper2000 Posted June 22, 2009 Share Posted June 22, 2009 Anyone know what the PSI is on a 91 manche fuel pump ? Also is it a GM 0-90 ohm sending unit? Thanks Link to comment Share on other sites More sharing options...
jpdocdave Posted June 22, 2009 Share Posted June 22, 2009 31 psi running with regulator connected for both 4 and 6 cyl motors Link to comment Share on other sites More sharing options...
Casper2000 Posted June 22, 2009 Author Share Posted June 22, 2009 :bowdown: Okay cool. I hope it's enough to run the LS1 i still havent gottin an answer about the pressure in need for it yet :dunno: Link to comment Share on other sites More sharing options...
Automan2164 Posted June 22, 2009 Share Posted June 22, 2009 :bowdown: Okay cool. I hope it's enough to run the LS1 i still havent gottin an answer about the pressure in need for it yet :dunno: I would also be worried about how much volume the pump could put out. Might be able to keep up with the demand of 6 reg injectors, but might fall behind trying to supply 8 thirsty v-8 injectors. Rob L. Link to comment Share on other sites More sharing options...
jpdocdave Posted June 22, 2009 Share Posted June 22, 2009 :bowdown: Okay cool. I hope it's enough to run the LS1 i still havent gottin an answer about the pressure in need for it yet :dunno: if you give me the application the ls1 is for i can look it up at work. off the top of my head its probably 50 or 60 psi though. Link to comment Share on other sites More sharing options...
Casper2000 Posted June 23, 2009 Author Share Posted June 23, 2009 Yea i got the answer i didnt want lastnight at the dealer... 60 psi for the LS1 at the least. So now i have on order a 255lph 60 PSI pump from lightning motor sports. Link to comment Share on other sites More sharing options...
