navigator Posted May 22, 2009 Posted May 22, 2009 will swap into my 88 MJ. it is a 5 speed in the floor with tilt, no cruise. my housing is actually busted where it should hold that plate in that has the problem with the screws backing out. just curious when shopping around which year mj and XJ will be an easy swap.
Eagle Posted May 22, 2009 Posted May 22, 2009 Anything from 86 through 94. In 95 they switched to a Chrysler column with an air bag.
navigator Posted May 23, 2009 Author Posted May 23, 2009 many thanks. Does it have to be exactly like mine (tilt, no cruise, floor shift) or can some of the options be different? I can take mine with me to make sure all the plugs are the same but is there anything else I need to keep an eye out for?
navigator Posted May 23, 2009 Author Posted May 23, 2009 ok, i think I have found one for a 94 XJ with cruise, i'll go look at it. Will it works since mine doesn't have cruise? That shouldn't matter should it?
