Shifter question
So, I found another comanche in the junkyard. It's got the 4 banger and a 5 speed ax-5. Does anyone know if the ax-5 and ax-15 shifter are interchangable? I don't need the shift tower, just the retention rings. I didn't want to go through all the hassle of tearing it out to find that they're different..
I'll be so stoked if they're the same, I'll have a $15 shifter to replace my damaged one.
Yeah, I've not made it ot to the yard yet to examine it. As long as the retainer ring measures up then I'm set.
Unfortunately I broke Mary Jane tonight, I think I burnt a fusible link from the starter relay to the fuel pump relays. I got no fuel pump noise at KO.
