richfactor Posted August 14, 2006 Share Posted August 14, 2006 I did a search but couldn't find a definitive answer. I have a 1989 comanche with the 2wd 6 cylinder engine and auto trans. I don't know what axles I have and the truck is currently in the shop getting painted. I want to get the 3" rough country lift kit with 31" goodrich AT's on the stock rims. I won't be doing any offroading anytime soon, just daily driver and some dirtbike hauling. Will this lift work for me or do I need to check what axle I have to determine that answer? I know I could wait and check on my axles but I'm ready to order the kit as I have ADD :eek: Link to comment Share on other sites More sharing options...
4play Posted August 14, 2006 Share Posted August 14, 2006 You should have the Dana 35C rear and 30 front. I have looked at the Rough Country web page and did not see a 3.5" lift available, but did see a 3" available. "Recommended Tire Size 31 x 10.50". http://www.roughcountry.com/Jeep_MJ_3in.htm Link to comment Share on other sites More sharing options...
richfactor Posted August 14, 2006 Author Share Posted August 14, 2006 Oops you are right, It is the 3" lift kit (edited my original post). I guess I should try emailing them tommorow to see what they say. Hopefully the ride is not to bad with the lift. Link to comment Share on other sites More sharing options...
DansGreyMj Posted August 14, 2006 Share Posted August 14, 2006 if its 2wd than it won't have a d30 but the 2/4wd suspensions are the same and double check th e parts are for an mj cuz the rear is different than an xj Link to comment Share on other sites More sharing options...
4play Posted August 14, 2006 Share Posted August 14, 2006 I guess the 2wd wouldn't have a D30 up front :oops: Sorry, I usually think in a 4wd mindset. Link to comment Share on other sites More sharing options...
