Shock Recomendations...
Sorry, I thought you meant you just needed fronts. i have 2-3" of lift on my truck too. i haven't installed them yet, but i bought the Toyota T100 rear shocks for mine. Measurements seem to be the closest to what I needed and what I read on here as to what would be the recommended extended and collapsed lengths. And the valving I hope will be appropriate based on the weight of the two trucks probably is only @200lbs different.
I use the ProComp ES9000's on everything I own. They are a great riding gas shock and they are not expensive at around $40 - $45 each :thumbsup:
Maybe I will give these a shot on the rear once I finish messing with it. Thanks :cheers:
